October 4, 20233 yr Hi, I'm trying to get iCloud sync to work with my Debian 12 (stable), the only thing which happens is that the browser opens, I then login in to icloud.com and there is a spinning circle. Nothing else happens, and after a while enpass tells me that I can retry the operation. Any idea what is going on? Enpass 6.9.0 on Linux Thanks.
October 4, 20233 yr Hi @caspergsht42 Please give the below steps a try and share your findings with me - Could you please check and confirm that the time setting is set to automatic on the device? If they are not, kindly set it to automatic. Try clearing the cache and cookies of the browser or use a different browser to set up sync. Ensure that you have allowed access to Enpass in your Firewall/Antivirus Settings. Moreover, if you are using any VPN service, try disabling it to check if the issue persists.
October 5, 20233 yr Author Hi @Abhishek Dewan, Thank you, removing ~/.cache/mozilla solved the problem.
