October 6, 20233 yr Hi. I've used Premium for years, and thank you for an awesome product. I use one single vault accross my 3 computers and my android, syncing to the same Dropbox account. Lately I noticed my Laptop hasn't been syncted to Dropbox for months, and when trying to connect (via desktop app) to said Dropbox, I get error: "No two vaults can be connected to same account for syncing data. Connected vault: Primary" And Primary is my vault connected to said Dropbox on the other devices. And this Laptop knows only of one vault. I have different vaults for other things on some of my devices, and me and my wife uses a "Familiy" vault for commen password shareing. But every single vault has its own cloud account (Dropbox/OneDrive/GoogleDrive) Any advice? Desktop app 6.9.1 (1515)on my Laptop.
October 9, 20233 yr Hi @GyroFalcon Please try the below troubleshooting steps and share your findings with us - On the device on which you are facing this issue, create a manual backup of your Enpass data. Once done, erase the data from local that can be done from the main app settings → Advance settings → Choose erase everything This will delete the existing data locally. Then, setup Enpass again from welcome screen, try connecting the sync with the required cloud.
October 9, 20233 yr Author Thank you. Followed your advices. After clearing everything, the app promted me with the Welcome-screen. Went right away to fetch from Dropbox, no problems. Then I put in my Premium-email, I noticed a cloud-sync error 209997, also in Vaults view. First thing I tried was quiting Enpass (ctrl Q), and started it up again. Now with now issues. Thank you. My only dilemma now is the changes to this exact vault i did before backup and clearing things. And this vault didn't have sync access for the last 3 months. Because now I'm only runninging latest cloud version of the Vault. Can I merge with the backup I made?
October 10, 20233 yr Hi @GyroFalcon Once you enable the synchronization, any changes you have made on either of the devices should be visible on all your devices.
October 10, 20233 yr Author I didn't risk it by restoring the backup, on top of the vault from the cloud. So I wiped the device again, restored from backup, then connected to dropbox. And everything is good now. Thank you.
December 29, 20241 yr Thank goodness for these forums. I'm on Windows 7 64-bit, and like GyroFalcon, after adding a local item and attempting to sync, I got the same error message. I also sync to DropBox, and I am also a long-time Premium member. I have no idea how long I haven't been syncing. I have Enpass on many other systems: other Windows, Linux and Android. Fortunately, following the instructions provided by Abhishek Dewan, I was able to get my Windows Enpass syncing with DropBox again. Thanks. Since all my data is in DropBox, I skipped the step of making a local backup. Any idea why this happens? It's a little alarming, since I keep all my authentication info in Enpass. If I were ever truly to lose this data, I'd be in a really bad situation.
