October 6, 20233 yr Hello, I've got different vaults on my NAS. Using folder sync with macOS devices works fine, so now I'd like to add my iOS devices to the folder sync. For testing purpose I dropped a test vault into my iCloud Account, so the file is on my iOS device. Here's the problem: When setting up Enpass for iOS, I can see the file in iCloud Drive, but I can't select it. It's just light grey and can't be selected. What am I doing wrong? Thanks & Cheers DerJan
October 9, 20233 yr Hi @DerJan We have received your query on support@enpass.io and have responded to the same. To avoid duplication of efforts and confusion, we request you to please revert to the same. We appreciate your understanding in this case.
December 6, 20232 yr I just created an account to report that this is still an issue - I just setup sync with another service (MEGA) and I can't select the dedicated folder, it's just grayed out
December 7, 20232 yr Hi @Karrq Please share the version of the Enpass app and OS you are using and we will get this checked for you.
