October 13, 20233 yr Hello, i recently got an Iphone 12, and installed the enpass app, but it does not sync with my google drive cloud. It worked on my andriod phone and it waorks on my windows pc. So any ansers? https://kodi.software/ https://dltutuapp.com/tutuapp-download/ Edited October 15, 20233 yr by xeliw42651
October 13, 20233 yr Hi @xeliw42651 To set up synchronization across your devices, please try the below steps - Steps for your old device on which Enpass is already set up and running - You can set up cloud sync on your device by going to - Setting’s → Vaults → Select the Vault for which you would like to setup sync → Setup Sync → Select the cloud → Continue. Steps for your new/other devices - On the welcome screen of the Enpass application on your device, choose Restore Existing -> Cloud account to which you synced the details above → Enter Vault password → Continue . All the passwords will be synced to your device. Note - Please ensure that you are using the same cloud account for synchronizing your Enpass data.
