October 24, 20233 yr Hey there, I was trying to set up a family shared vault which should be available in our home network only by design. Folder sync on a local NAS seemed a great way to do this. And it worked perfectly well with my Windows and Mac machines. However, if I try to set this vault up on iOS/iPadOS (iPhone and iPad), there's no Folder Sync to choose from. I am an "legacy" Pro user, no active Premium subscription. Thanks a lot!
October 25, 20233 yr Hi @awaescher I would like to share that we provide the option of the folder sync in the sync flow only, rather than the restore or create a new vault flow and it seems from the screenshot shared that you are trying to create or restore a new vault. That is why the folder sync option is not showing.
