April 29, 20188 yr Hi. Since I'm using the same email for almost every account I thought it would be useful if Enpass proposes me to set that mail for this account. So what I mean by that is that when you manually create new login credentials that Enpass will propose you to use your e-mail you've been using the most or maybe that you could set an email address to use for auto-fill in. Let me know what you think about it. I know it's not that bad to type the email in every time but it would be easier with that feature.
April 30, 20188 yr Hi @niklas, Thanks for your suggestion. This is something we do have plans to implement in our next major update. Cheers!
July 6, 20188 yr Enpass can have a dropdown list of emails that we have used so that we can click to choose instead of typing every single time. This also limits wrong typing sometimes. Can you make it into version 6 please?
July 7, 20188 yr Hey @samep Yes, this feature will be available with the update as a part of Identity management. Cheers!
February 12, 20197 yr Author Enpass 6 is already here but I didn't see this feature so far. So what is the current status of this feature suggestion @Anshu kumar?
February 13, 20197 yr It's already in our priority list and will be available with the subsequent update. Thanks!
