November 2, 20233 yr Hi, it is not possible in Android 13 to create a sync with a folder which is on a network share in the wlan availbale, because the dialog only displays the local folders of the android smartphone! Or is there hidden trick?? In iOS no problem ... --Mike
November 3, 20233 yr Hi @sysfox Please share the version of the Enpass app you are using as well and I'll get this checked for you.
November 9, 20232 yr Hi @sysfox Thank you for sharing the details. I have duly noted your feedback and shared it with out development team for further consideration and feasibility checks. I will also be sure to update this forum once I have more information on this case. Your patience in the meantime is greatly appreciated. #SI-3536
November 15, 20232 yr Author Hi, any news? It's now 2 weeks since my intial question...Shouldn't be to complicate at least to reproduce the issue. Otherwise, if Enpass stops development and/or support for its products (which is my impression), pls let us know, as then i need to check alternatives. Thanks.
December 7, 20232 yr Hi @sysfox Our dedicated team was able to reproduce the bug due to which this issue is occurring and they are working on fixing it. We will be sure to update this forum once a patch addressing this concern is released. Kindly bear with us until then.
May 12, 20242 yr Our technical team is actively working on a solution. Fixing this bug may take some time, and the resolution will be included in the upcoming updates of the application.
April 11, 20251 yr Fixing this bug may take some time you say. I can understand that. But how much time do you need? This issue was posted nov 2023, now its april 2025. I am also wating for this bug to be solved. I would like to have my databas in controlled Environment as you promised. I want to use my NAS as server not a computer running all the time.
April 22, 20251 yr The ability to host the Enpass database on a NAS is a feature many users, including yourself, have been waiting for. While we don’t have a confirmed ETA at this time, I’ve highlighted your request again with our development team.
