Cannot share to device running ios17 via airdrop
Receiving an enpass item into a phone running ios16 works- the user is prompted to open the file in enpass and the item is added.
Receiving in ios17 results in no prompt and automatic saving to “Files”.
there appears to be no way to open the saved  file in enpass. Trying to  “share” the saved file with enpass results in “invalid file”, or similar from enpass.
no issues sending from ios17 device to ios16 device.
is there a way to share individual logins via airdrop into iOS 17?
Version 6.9.3(776).
I set up a phone that I had updated to iOS 17, reset, and with a new account yesterday and enpass was downloaded yesterday.
it appears Apple has changed how air drop works - see https://developer.apple.com/forums/thread/737971?page=1#767265022
However, even if one cannot avoid saving the file, opening it is the issue.
btw if you share via iMessage it still works.
Hi @MichaelisHuman
 Our team was successfully able to replicate the glitch due to which this issue is occurring and they are now working on a fix which will be implemented soon in the future version of the app. We appreciate your patience and cooperation while we work on fixing this bug.
#SI-2589
