December 4, 20232 yr As enpass supports multiple vaults, it would be need if accent colors could be associated with a vault, in the same pane as the name and icon is set. Then, in the "All Items" view, when all vaults are selected, the items would have the same accent color as its background. Easier to spot which items belongs where
December 5, 20232 yr Hi @Ivarson I have duly noted your feedback and shared it with out development team for further consideration and feasibility checks. I will also be sure to update this forum once I have more information on this case. Your patience in the meantime is greatly appreciated. #SI-3564
August 25, 20242 yr I too would like this. The list in the desktop window makes no distinction as to what vault each entry is in. I was going to suggest adding vault to the sort by (this would still be desirable) but the colors (or maybe the vault icon) on each item.
