May 5, 20188 yr Support for multilinear fields (like Notes) would allow for a location to store 2FA backup codes (Google issues then in batches of 10). This data is sensitive and should be masked.
May 7, 20188 yr Hi @chribonn, Thanks for writing in. The feature for adding multi-line text has already been implemented and will be available in the next major update. Cheers!
October 14, 20188 yr On 5/7/2018 at 1:17 AM, Anshu kumar said: Hi @chribonn, Thanks for writing in. The feature for adding multi-line text has already been implemented and will be available in the next major update. Cheers! Very happy to read this. Of the many features I wish to see with this software, sensitive notes (or multilinear fields) is a must imo, especially for 2fa codes. When can we expect to see this happen? Edited October 14, 20188 yr by Pete
January 7, 20197 yr On 5/7/2018 at 7:17 AM, Anshu kumar said: Hi @chribonn, Thanks for writing in. The feature for adding multi-line text has already been implemented and will be available in the next major update. Cheers! could you, please, add some TAG or other mark to issues that were resolved ? or move feature requests that were done to separate forum folder ?
April 2, 20197 yr On 5/7/2018 at 1:17 AM, Anshu kumar said: Hi @chribonn, Thanks for writing in. The feature for adding multi-line text has already been implemented and will be available in the next major update. Cheers! 1 year later, any update on this?
April 2, 20197 yr Author 1 hour ago, Pete said: 1 year later, any update on this? Hello, I can confirm that version 6 supports multiline fields. These may be set to sensitive. I use these type of fields for 2FA backup codes.
April 2, 20197 yr 2 minutes ago, chribonn said: Hello, I can confirm that version 6 supports multiline fields. These may be set to sensitive. I use these type of fields for 2FA backup codes. Omg, you're right, there it is. I went looking for it earlier but missed it, now I see it lol What version did this get included? I guess I missed a changelog somewhere.
April 2, 20197 yr Author 2 minutes ago, Pete said: Omg, you're right, there it is. I went looking for it earlier but missed it, now I see it lol What version did this get included? I guess I missed a changelog somewhere. Hi Pete, I think it appeared in version 6.
