January 9, 20242 yr How to I change my primary vault from icloud to google drive? As I no longer have any apple products and they refuse to have sms auth I wont be able to even log in to my Icloud when I stop using my last devide, so switching my enpass to google drive would be the best option. But how do I switch the primary vault?
January 9, 20242 yr 49 minutes ago, zorixxe said: How to I change my primary vault from icloud to google drive? As I no longer have any apple products and they refuse to have sms auth I wont be able to even log in to my Icloud when I stop using my last devide, so switching my enpass to google drive would be the best option. But how do I switch the primary vault? vaults are local-first in Enpass. What you'd do is to remove the data "from cloud" on one of your devices with Enpass, then immediately setup a new sync to Google. If you've got Enpass on more devices still syncing towards apple, youll get a red warning on them saying no data was found on Apple iCloud, ignore and then setup sync to Google on them as well. make sure you've got backups when doing this, esp. if you're only using Enpass on one device, either automatic ones or create a manual backup, since you'll remove Working with vaults — Enpass User Manual-Desktop 6.7 documentation
