May 9, 20242 yr Hello, i try to configure Enpass under Linux Mint 21. Installation works fine, the syncfolder ist stored on a network drive which is mounted by fstab (and is displayed and accessible from the desktop). These folder can used for sync from a windows version of Enpass and from an android device without problems. The syncfolder is a network drive, mounted in the home-directory of the current user ("SyncFiles"), but is not displayed in the folderselect-Dialog of Enpass. Can anyone point me in the right direction? Any help would be appreciated. Best regards Dominion
May 15, 20242 yr Author Problem solved: Using webdav. I have to change the sync on all other devices, but it works, that's the main thing.
