June 26, 20242 yr The scrollbar is currently only visible when hovered over. This should be changed to “always visible” or at least “visible while scrolling.” With the hidden scrollbar, it is impossible to determine my current position in the list and the total length of the length – two important functions that a school should have. Thank you for considering this improvement. -- macOS 14.5 Sonoma, Enpass 6.11.0 (1676) Мас App Store
June 27, 20242 yr I've reported this issue to the Enpass technical team. They are currently investigating it, and I will reach out to you with updates as soon as I receive them. #SI-3668
