August 28, 20242 yr Is it normal when I activate autofill (beta) on chromeos it only works for some minutes? When I want to use it next time I have to uncheck and check it again in settings
September 3, 20242 yr No, this is not normal behavior. It sounds like an issue specific to the beta version. Could you please try downloading the stable version of Enpass and check if the same issue persists? If you continue to experience this problem, please let us know so we can investigate further.
September 8, 20242 yr I have posted this same issue several months ago and have been waiting for the fix.
September 12, 20242 yr To help us investigate this further, could you please share the following details with us? Device model and operating system version Enpass version installed on your system With this information, we can provide more specific guidance to resolve the issue. Thank you for your cooperation, and we look forward to helping you get this sorted out.
