September 29, 20242 yr Buongiorno, ho acquistato una licenza personale a vita, sono deluso dalla mancanza di funzioni da parte di Enpass, vorrei la possibilità di uno sblocco rapido tramite pin, ovviamente se il pin non è corretto una volta che la master password deve intervenire, non riesco a capire perché questa funzione non c'è. Grazie.
October 10, 20242 yr I understand your concern, but I’d like to clarify that the feature for quick unlocking via PIN is already available in Enpass. You can enable this option by navigating to the Enpass security settings and selecting the "Unlock with PIN" option. Once activated, you'll have the flexibility to unlock your vault using either the PIN or your master password.
October 15, 20242 yr Author Hi thanks for your reply, I know very well that there is that setting I also tried it, but sometimes it asks me for the master password and this is very inconvenient, with Android if you close all the apps and then reopen Enpass asks you for the master password and all this is inconvenient, it should always ask for the pin then if you type the wrong pin obviously it should ask for the master password. Thank you mllle.
October 18, 20242 yr This is the intended behavior of Enpass. Whenever you completely close the app or restart it, Enpass will ask for the master password.
