October 9, 20242 yr I'd be great if the browser extension sorted suggested login details by recent usage. For some domains, I have quite a lot of account in enpass but use only one or two on a regular basis. Maybe the last usage of a credential or the count how often it was used could be used for determining the order.
October 10, 20242 yr You can use the "Frequently Used" short filter to quickly access the most commonly used login details. This feature helps to prioritize the credentials you use regularly and sorts them accordingly for easier access.
October 15, 20242 yr Author Hi Amandeep, that helps a bit. But to be clear, I want the browser extension to show the recently used or frequently used logins first. Thanks for your help.
October 18, 20242 yr To clarify, the behavior you're experiencing applies to both the Enpass app and the browser extension. Recently used or frequently used logins should be shown first in both environments for convenience. If you're not seeing this in the extension, please try refreshing the browser or restarting the extension to ensure proper functionality. y.
