February 2, 20251 yr I don't know whether this was caused by a bug/data corruption or an update. (I have Play Store Beta enabled and I'm currently running Enpass 6.11.8.1068) Since I'm on the beta channel I'll report the issue I just ran across (even if the current version might not be a beta): I started Enpass on my phone (Pixel 7 Pro, Android 15, Patch January) and it asked for my finger print but didn't want to unlock my vault. I entered the correct password (several attempts), it told me the password is wrong. I assume the vault got corrupt somehow. I wasn't able to trigger resyncing the vault before entering the "correct" password. I deleted the app's data and resynced from my vault and everything runs fine again now. This is just a report in-case this might be a widespread problem. If it isn't, then great. If it is: hopefully my report leads to the issue being fixed in beta phase before it affects most users. Regards Djfe
February 17, 20251 yr Thanks for reporting this issue and for being part of the beta channel! We've addressed this in the stable release, so updating to the latest version should prevent this from happening again. If you’re still experiencing the issue after updating, please let us know—we’d be happy to investigate further.
