Can't sync using Google Drive. Sync error. Something went wrong while syncing with Google Drive. Error code: 409975
I have multiple linux and android devices. I follow the recommendations from https://discussion.enpass.io/index.php?/topic/28224-cant-sync-using-google-drive.
I tried different Google Accounts too.
Every time, no matter Primary or any other vault, the first device syncs well, the others fail to connect. Androids with "something went wrong", linux apps with "Sync error. Something went wrong while syncing with Google Drive. Error code: 409975"
Please tell me how to provide more verbose info to you, thanks.
Edited by Denis P
OK, resolved.
 tried:
- reinstalling from normal pkg registry (arch/extra). Same error.
- reinstalling from flathub. Same error.
- moving everything to Folder Sync -> Syncthing. Got I believe "Error code: 809975".
The last one made me think that the problem might be in a corrupt database (since there's no normal logs nor open info about error codes, sic!).
So what finally helped was to re<move,name> `~/Documents/Enpass` dir.
Can be closed.
