July 2, 20251 yr No clue why. Tried looking for it but can not find it anywhere Firefox 140.0.2 + Windows 11
July 2, 20251 yr If the Enpass extension icon isn’t showing up in your Firefox toolbar after installation, please try the following steps: Check Extension Visibility Click the puzzle icon (Extensions) on the Firefox toolbar. If Enpass appears in the list, click the pin icon next to it to make it visible on the toolbar. Verify Extension is Enabled In the address bar, type about:addons and press Enter. Locate the Enpass extension and ensure it’s installed and enabled. Restart Firefox After installation, sometimes a browser restart is required for the extension to fully load. Reinstall the Extension If the icon still doesn’t appear, try uninstalling and reinstalling the Enpass extension from the Firefox Add-ons Store. If you've tried all the above and the issue persists, feel free to share more details and we’ll be happy to assist further.
July 3, 20251 yr Author I did try all of that. Was able to manage to fix it though. Not sure exactly how just reinstalled. Saw a place to get extension icon to appear so checked it off to be sure it happens this time. Now works great again. Thanks.
July 3, 20251 yr Author Plan on using Firefox portable too, maybe, so if this ever happens again I can find the conflict or issue.
