July 17, 20251 yr I'm a web developer, so I deal with localhost a lot, which most of the time is http:// (insecure). The password system to my application doesn't allow simple passwords, and it's convenient to have one entry for the various environments. But I can't use autofill on localhost. Could we get a per-item opt-in that allows filling http:// forms? Perhaps with a coloration or other cue that the form isn't secured?
July 18, 20251 yr In the Enpass app, please update the item's URL field to include "http" and check if the issue is resolved. If the issue persists, you can share the below details to our support team at support@enpass.io so they can investigate it further Your Enpass app version Your macOS version Browser version you are using
