August 7, 20251 yr Enpass doesn't seem to be compatible with RHEL 10. When trying to install Enpass, the following error is returned: Error: Problem: cannot install the best update candidate for package enpass-6.11.12.1953-1.x86_64 - nothing provides libXss.so.1()(64bit) needed by enpass-6.11.12.1953-1.x86_64 from enpass libXss.so.1 is a runtime library for X.Org, which was removed from RHEL 10, and I assume Fedora dropped the support as well.
August 8, 20251 yr Thanks for reporting this. I’ll check with our technical team regarding the missing libXss.so.1 dependency on RHEL 10 and see what options are available. I’ll update you as soon as I have more information from them. #SI-4460
