September 16, 20251 yr I have an nextcloud server running. My enpass syncs to it now fine. I now have a onedrive and want to sync to it. I connected enpass to it, but when I switched to the one drive there are zero records. I need my nextcould vault data to go over to onedrive.
September 17, 20251 yr Enpass does not automatically transfer data between different cloud services. When you connect to OneDrive, it will start with an empty vault unless your existing data is manually moved. You’ll need to move your Enpass data from Nextcloud to OneDrive in order to have all your records available there and enable syncing across your devices using OneDrive. Alternatively, you can continue syncing across devices using Nextcloud if that setup works better for you.
November 24, 2025Nov 24 Enpass does not automatically transfer storage between services. Alternatively, export your storage from Nextcloud and then import it into OneDrive to sync there. Or you can use CloudMounter. Found a good article https://mac.eltima.com/get-more-storage-on-mac/ Edited November 28, 2025Nov 28 by Adamdd
