September 18, 20251 yr Since few days, when I want to use Enpass from an app, Enpass opens with the message « Please complete Enpass setup before using it creating or signing in using passkey » It happen for multiple application. Note that I can open and use Enpass separately. It means that I have to copy the password from Endpass and paste it to my application How to fix this? I don't see how to "complete" the Enpass setup Enpass Version : 6.11.13 IOS : 18.6.2 Edited September 18, 20251 yr by horodav
September 18, 20251 yr Author here is the solution given by enpass team: Open the Enpass app. Create a temporary (dummy) item, such as a test login. Save the item and then check if Autofill is now working in the app where you previously faced the issue.
