October 26, 20251 yr I've been using Kiwi browser for a long time, but it isn't being updated anymore. Now I'm looking for a new browser on my android phone. Quite some browsers I've tested so far (smaller, more obscure ones) don't work with autofill. Therefor I thought to turn the search around and look at android browsers that do work with autofill. I've now spend quite some time searching for a list of compatible browsers, but I can't seem to find one. Which android browsers work with Enpass autofill?
October 28, 20251 yr Enpass on Android supports autofill through the following three methods. For the best experience, please ensure all of them are enabled. If they’re already active, try toggling them off and back on: Using Autofill on Android Android Autofill Framework Android Accessibility Enpass Keyboard Enpass works seamlessly with most major browsers that support Android’s Autofill Framework, including: Google Chrome Mozilla Firefox (Android version) Microsoft Edge Other mainstream Android browsers that support the standard autofill service
