December 31, 2025Dec 31 New passwords added on macOS, prompting successful synchronization (Dec 29, 311 passwords). But on other devices (mobile, Windows) I can't get the latest files via WebDAV (Dec 27, 309 passwords) My files are on a NAS and I can see that they are not up-to-date either (Dec 27) Finally disconnected and relinked on macOS to restore to the latest data version. But I don't know when this will happen again. I hope the above info helps you guys with this issue
January 4Jan 4 Author This happened again today, the password were updated on the phone, and the NAS password file was up to date, but it would not update to the latest version on macOS without any sync error message. So it is possible that there is a problem with the macOS version of Enpass WebDAV synchronization. In the access log of NAS, I can see the request log of macOS version, but there is no data update.
July 30Jul 30 On 1/4/2026 at 1:30 PM, sbugzu said: This happened again today, the password were updated on the phone, and the NAS password file was up to date, but it would not update to the latest version on macOS without any sync error message.So it is possible that there is a problem with the macOS version of Enpass WebDAV synchronization.In the access log of NAS, I can see the request log of macOS version, but there is no data update.speed starsI have noticed similar behavior with WebDAV synchronization where Enpass appears to connect successfully, but the latest changes are not always pulled or pushed across devices. The fact that the NAS logs show requests from the macOS client but no actual data update suggests the connection itself is working, while something may be failing during the synchronization process. Hopefully the Enpass team can check the macOS WebDAV sync mechanism and identify whether there is a caching, conflict detection, or update handling issue causing this. Edited July 30Jul 30 by AdrianHodges
