How to reset Breached Website warning?
How do I get the breached website warning to reset for an entry? I have changed my password for the entry, but the breached website warning still appears.
Edited by Rojma
  • Rojma changed the title to How to reset Breached Website warning?
  • 2 weeks later...
Good question.
Bump.
Devs do you have an answer for this question?
You can select the item, right-click, and choose to exclude it from the Password Audit.
@Amal wouldn't that cause it to not be monitored in the future? In my opinion, the warning for the item should reset once you change the password. You should also have an option where you can manually reset the warning, for example if you know you have already changed the password.
Edited by Rojma
