May 12May 12 EnvironmentOS: Windows 11 (Kernel Version 26100, Build 10.0.26100.7920)Architecture: x64, 20 logical processorsEnpass version: [insert your version]Crash date: April 20, 2026 — 15:32:59 UTC+2Bug DescriptionEnpass.exe is causing a reproducible kernel-level crash (Blue Screen of Death) on Windows 11 with stop code DRIVER_IRQL_NOT_LESS_OR_EQUAL (bugcheck 0xD1).The crash occurs inside NETIO.SYS at function StreamInvokeCalloutAndNormalizeAction+0x5c, triggered by a Windows Filtering Platform (WFP) callout registered by Enpass. The faulting process is explicitly identified as Enpass.exe in the minidump.Minidump Analysis (WinDbg !analyze -v)BUGCHECK_CODE: 0xD1 (DRIVER_IRQL_NOT_LESS_OR_EQUAL) PROCESS_NAME: Enpass.exe FAILURE_BUCKET_ID: AV_NETIO!StreamInvokeCalloutAndNormalizeAction FAILURE_HASH: {c2ca2d1f-cfdc-88d5-c7bc-7693b8f0de04} FAULTING_INSTRUCTION: NETIO!StreamInvokeCalloutAndNormalizeAction+5c fffff805`607c43a8 488b4808 mov rcx, qword ptr [rax+8] → Access Violation: reading address 0x0000000000000008 at IRQL 2 (DISPATCH_LEVEL) STACK TRACE: nt!KeBugCheckEx nt!KiBugCheckDispatch+0x69 nt!KiPageFault+0x468 NETIO!StreamInvokeCalloutAndNormalizeAction+0x5c NETIO!StreamCalloutProcessingLoop+0x147 NETIO!StreamProcessCallout+0x2f4 NETIO!ProcessCallout+0x821 NETIO!ArbitrateAndEnforce+0x5af NETIO!ArbitrateAndEnforceCallout+0x4d nt!KxSwitchKernelStackCallout+0x2e nt!KiSwitchKernelStackContinueRoot Cause AnalysisEnpass registers a WFP stream callout (via FwpsCalloutRegister) to inspect network traffic — likely for phishing protection or connection monitoring. The callout is passing an invalid or already-freed NET_BUFFER_LIST pointer to NETIO!StreamInvokeCalloutAndNormalizeAction. When the function attempts to dereference offset +0x8 of the returned pointer (rax+8), it reads from address 0x0000000000000008 — a near-null pointer, indicating a use-after-free or NULL dereference in the callout handler.This is a kernel-mode bug: WFP callouts operate at DISPATCH_LEVEL (IRQL 2) and must not access pageable or invalid memory. The crash is 100% reproducible and consistently attributed to Enpass.exe across multiple minidumps.ImpactSeverity: Critical — system crash (BSOD), data loss riskFrequency: Recurring (multiple crashes observed)Workaround: Uninstalling Enpass eliminates the crash entirelySteps to ReproduceThe crash appears to trigger during active network usage while Enpass is running in the background. No specific user action in Enpass is required — simply having it running as a startup process is sufficient.Suggested FixReview the WFP stream callout implementation (FwpsCalloutRegister / FwpsStreamInjectAsync). Ensure that:NET_BUFFER_LIST references are validated before dereferencing at DISPATCH_LEVELCallout handlers properly handle NULL or freed buffer pointersThe callout is unregistered safely on process exit with FwpsCalloutUnregisterByIdReference: Microsoft WFP Stream Callout documentation 042026-19312-01.dmp
