June 17, 20188 yr It would be REALLY useful to provide an on-screen notification if CAPS LOCK (and indeed NUM LOCK, if that is also possible) are active when typing the Master Password. If you have changed to CAPS (or NUM on a laptop keyboard, even though that is quite infrequent) it is not obvious when the Master Password you typed in fails, and some indication of status in the app on this screen would address this without compromising security.
June 18, 20188 yr Hi @AndyMac, Thanks for your suggestion. I've noted it down and forwarded to the team for consideration. Cheers!
