September 19Sep 19 Since yesterday whenever Discover looks for updates, it gives me this message twice:"Signature verification for Repository Enpass failed"I'm on openSUSE Tumbleweed 20260912 withKDE Plasma 6.7.5Qt 6.11.2Kernel 7.2.4-1-defaultGraphics: Waylandandenpass-6.11.12sudo zypper se -s enpassgives me thisLooking for gpg keys in repository Enpass. gpgkey=https://yum.enpass.io/stable/x86_64/repodata/repomd.xml.key Repository Enpass does not define 'gpgkey=' URLs. Looking for gpg keys in repository Enpass. gpgkey=https://yum.enpass.io/stable/x86_64/repodata/repomd.xml.key Warning: File 'repomd.xml' from repository 'Enpass' is signed with an unknown key '29CD5AFE005874D6'. Note: Signing data enables the recipient to verify that no modifications occurred after the data were signed. Accepting data with no, wrong or unknown signature can lead to a corrupted system and in extreme cases even to a system compromise. Note: File 'repomd.xml' is the repositories master index file. It ensures the integrity of the whole repo. Warning: We can't verify that no one meddled with this file, so it might not be trustworthy anymore! You should not continue unless you know it's safe. File 'repomd.xml' from repository 'Enpass' is signed with an unknown key '29CD5AFE005874D6'. Continue? [yes/no] (no): Retrieving repository 'Enpass' metadata ....................................................................................[error] Repository 'Enpass' is invalid. [Enpass|https://yum.enpass.io/stable/x86_64/] Failed to retrieve new repository metadata. History: - Signature verification failed for repomd.xml Please check if the URIs defined for this repository are pointing to a valid repository. Warning: Skipping repository 'Enpass' because of the above error. What could be the issue?My instinct is to not just nilly willy continue with an unknown key. Edited September 21Sep 21 by FlashBytes Removed unnecessary information.
