October 3Oct 3 I am seeing a repeatable startup/unlock crash on one Windows PC after reboot.EnvironmentAffected PC — MIKE-LPWindows 11Enpass Password Manager from Microsoft StoreEnpass version: 6.12.6 (2710)AppX version: 6.1206.2710.0Architecture: x64Package:SinewSoftwareSystems.EnpassPasswordManager_6.1206.2710.0_x64__fwdy0m65qb6h2Sync provider: OneDrive PersonalNo observed sync errors during normal useComparison PC — MIKE-CUWindows 11Enpass Password Manager from Microsoft StoreEnpass version: 6.12.6 (2722)AppX version: 6.1206.2722.0Architecture: x64Package:SinewSoftwareSystems.EnpassPasswordManager_6.1206.2722.0_x64__fwdy0m65qb6h2Same OneDrive Personal syncDoes not exhibit this problemProblemAfter rebooting MIKE-LP:Windows starts normally.Enpass opens and asks for the master password.If the network connection is active when I enter the master password, Enpass crashes.If I disable the network connection before entering the master password, Enpass unlocks normally.I can then re-enable networking and continue using Enpass normally.This appears to be specifically related to the initial post-reboot unlock while networking is available.I am not experiencing OneDrive sync failures during normal operation.Troubleshooting performedI confirmed both systems are using the Microsoft Store version of Enpass.On MIKE-LP:winget list Enpassreturns:Name Id Version Source ----------------------------------------------------------- Enpass Password Manager 9NJ3KMH29VGJ 6.1206.2710.0 msstoreRunning:winget upgrade Enpassreturns:No available upgrade found. No newer package versions are available from the configured sources.I also ran:wsreset.exeand checked Microsoft Store updates again. The Store still does not offer anything newer than 6.1206.2710.0 on MIKE-LP.Both systems are x64, so the build difference is not an x64 vs ARM64 difference.QuestionsIs 6.12.6 (2710) an older Microsoft Store package revision than 6.12.6 (2722)?Were there any crash, startup, networking, authentication, or OneDrive-related fixes between builds 2710 and 2722?Is build 2722 being distributed through a staged Microsoft Store rollout?Is there a supported way to obtain build 2722 on MIKE-LP for testing?Are there logs or crash dump files I can collect that would help diagnose why Enpass crashes only when the network is enabled during the initial post-reboot unlock?The fact that disabling networking before entering the master password consistently allows Enpass to open seems like an important diagnostic clue.I would be happy to provide additional logs or testing information if needed. Edited October 3Oct 3 by Mike134
