June 22, 20188 yr Whenever I enter the master password I set up (why was it required to be SOOO long this time? Why couldn't I just use the same master password I had for the regular pass? First problem) It says it's not correct. Since I was never able to import the files from the regular enpass (problem 2), how do I just start over and create a new data file? I can't see any way to do it without entering the master password. So there has to be a way to at least delete the locked file and start over, how? if not, why not?
July 5, 20188 yr Hi @Arnas Thanks for writing in. It would be a great help if you can elaborate the scenario bit more what problem are you facing while restoring Enpass 5 data. Does Enpass crash? Is it doing a partial restore? Is it not accepting master password? Thanks for your co-operation.
July 5, 20188 yr Problem is when I connect to Google Drive for auto sync with same master password as Enpass 5 it not sync my data from the Google Drive, Enpass 6 have empty home page. When I tried Export data from Enpass 5 to 6 it not possible import to Enpass 6 I found only export button. Or Enpass 6 is not compatible with Enpass 5 data and can't sync with Google Drive from Enpass data folder ?
July 6, 20188 yr Hi @Arnas, Thanks for writing back. First of all, I would like to share that restoring Enpass 5 data directly from the cloud is not possible, you need to restore it with the backup file. Please follow these steps for restoring Enpass 5 data into Enpass 6. Step 1: Open Enpass 5 --> Take the backup of Enpass data and save it manually on the system. Step 2: Quit Enpass 6 (If running). Go to User Documents folder --> Rename Enpass6-Beta folder. Now Open Enpass 6 --> It will prompt you a welcome screen --> Select Backup file --> And follow the instruction. Hope this helps!
