July 13, 20188 yr I would like to see the option to minimize to taskbar on launch. When windows starts up I don't want the full app in my face on the desktop.
July 16, 20188 yr Hi @Sbug, Enpass already have the feature of Minimize app to the system Tray on system startup. Please let me know the version of OS and Enpass which you are using so that I can investigate further. Thanks!
July 17, 20188 yr Author I'm using the Beta 2 of the Traditional Windows Enpass 6. Under General. I only have Run -> Open Automatically at System Startup. It does minimize to tray once it's started but I want it to start minimized. Also the option to NOT prompt to save passwords isn't working. Every time I login to a website that isn't in Enpass I get a popup window. Edited July 17, 20188 yr by Sbug
April 21, 20197 yr On 7/16/2018 at 8:05 PM, Anshu kumar said: Hi @Sbug, Enpass already have the feature of Minimize app to the system Tray on system startup. Please let me know the version of OS and Enpass which you are using so that I can investigate further. Thanks! Hi I have the same issue on my two computers with LinuxMint 19.1 and OpenSuse Leap 15. Enpass 6.0.6 (323). Both commands are "/opt/enpass/Enpass -minimize" but them both do not start in the tray. The mint's enpass starts in full window mode and the suse's enpass starts minimased on task panel - not in the tray. This issue appeared a couple of months ago. What ever I do this it's still on.
April 22, 20197 yr Hey guys, Sorry for the trouble you are going through. This issue has been fixed, and an update v6.1 with the fixes will be rolled out soon. We appreciate your patience.
April 1, 20251 yr On 4/22/2019 at 4:05 PM, Anshu kumar said: Hey guys, Sorry for the trouble you are going through. This issue has been fixed, and an update v6.1 with the fixes will be rolled out soon. We appreciate your patience. Is this fixed? When opening Enpass, it does not hide itself to tray and opens up a full Enpass window. I am using (autohotkey) AHK to launch Enpass, so is there a command line parameter I can use to open it in background and stay in tray. The "minimize to tray" is just for minimizing instead of closing the app when pressing the "x" close button.
