July 18, 20188 yr Hi! When i try login with Chrome browser it doesn't fill username, just password and in some website fill email instead username. I have tried many site it same problem all the time.
July 19, 20188 yr Hi @Arnas, Thanks for reporting the issue. Please let me know if you're trying to autofill by using "Autofill Using Keyboard and Notification" Option or "Manual Filling Using Keyboard Only". Also, it would be great if you can share the URL of particular websites. Thanks!
July 19, 20188 yr Author Hi @Anshu kumar Often I try to use autofill with the notification and in all those sites that autofill only password fields. I can write more sites but it is same problem to me on all sites. If I fill manually with keyboard, it does not automatically fill any field, but it can be manually filled. Sites list : https://www.webhallen.com/se https://www.cyberphoto.se/kundvagn/logga-in https://gitlab.com/users/sign_in https://login.schibsted.com/flow/login https://www.airbaltic.com/en/index https://www.netonnet.se
July 20, 20188 yr Hi @Arnas Thanks for sharing the details. I've noted it down and forwarded to the testing team to look into it. Thanks!
July 20, 20188 yr I'm also experiencing this with Dolphin browser. It will only fill in the password field but not the username/email. I have "Autofill Using Keyboard and Notification" turned on. I'm using a Galaxy S7 on stock Oreo and I've only once seen the Enpass Autofill popup which I presume is from the Android O framework. However this only works if the Autofill Using Keyboard option is turned off. Otherwise I have to tap the notification icon and half the time I have to tap the notification icon repeatedly before it brings up the app. Edited July 20, 20188 yr by Sbug
July 21, 20188 yr Hey guys, We have tracked the issue and a fix will be available in the next update. Thanks for your co-operation and keep reporting.
July 22, 20188 yr On 7/21/2018 at 6:37 AM, Anshu kumar said: Hey guys, We have tracked the issue and a fix will be available in the next update. Thanks for your co-operation and keep reporting.
