July 24, 20188 yr Hi, I'm really enjoying Enpass 6 beta in Windows, but when importing passwords from other managers, Enpass does not recognize the "Groups" (or "Folders") field, even if I edit the CSV file and manually type "Tags". I believe that Enpass should recognize it automatically or at least that an import wizard appears to customize the fields as in version 5. Of the rest, Enpass 6 seems to me a marvel.
July 25, 20188 yr Hi @gabeweb, Thanks for reporting this issue. I've noted it down and forwarded to the dev team to look into it. Thanks!
July 25, 20188 yr Author 2 hours ago, Anshu kumar said: Hi @gabeweb, Thanks for reporting this issue. I've noted it down and forwarded to the dev team to look into it. Thanks! Nice, thank you! Yes, even if I create the labels in Enpass manually and import passwords with the same tags, Enpass ignores them.
