July 28, 20188 yr Just a few suggestions from little old me ... Make the Menubar icon optional Ability to sort custom categories alphabetically along with the built-in categories Ability to preview attachments in the app Scrolling with a scroll wheel doesn't work Also how will we know when a new beta is posted? Edited July 28, 20188 yr by RHPT
July 31, 20188 yr Hi @RHPT, Thanks for the suggestion. On 7/29/2018 at 2:43 AM, RHPT said: Make the Menubar icon optional Ability to sort custom categories alphabetically along with the built-in categories I've noted it down. On 7/29/2018 at 2:43 AM, RHPT said: Ability to preview attachments in the app Already in the roadmap. On 7/29/2018 at 2:43 AM, RHPT said: Scrolling with a scroll wheel doesn't work Please share some more info so that we can investigate further. On which OS and screens are you facing this problem? Which Enpass version are you using? On 7/29/2018 at 2:43 AM, RHPT said: Also how will we know when a new beta is posted? You'll get notification within the app itself or you can also check it on our Forum Post or Twitter. Cheers!
August 3, 20188 yr Author I have issues when trying to scroll using the scroll wheel the records in Enpass (second column). I am using a Logitech MX Master 2S and a Mac running High Sierra 10.13.6 (17G65) and Enpass Beta 6.0.0 (187)
