July 31, 20188 yr The first thing I tried with the new android beta-app was to synchronise with dropbox. I clicked synchronise with dropbox, opened the dropbox website and autorised the oauth-token and got the message "continue in the app" or " redirect to app" or some similar message. But when I clicked that button nothing happened. If I went back to the app manually, the app was still waiting for the oauth-token and nothing happens. I tried this multiple times and always the same error. (later I realised this might not be supported, and I would need to use a backup-file and restore from that. But still an error or a warning or something would be nice if this is the problem)
July 31, 20188 yr Hi @Fredrik, Thanks for writing in. Please let me know the default browser which you've configured on your device so that we can help you better. Thanks.
August 9, 20188 yr Hi @Fredrik Thanks for your reply. You're facing this problem due to a known bug and our dev team is looking into it. Meanwhile please make Chrome as default browser and then try to sync. Hope this helps!
