August 2, 20188 yr I get this error too occasionally. However it doesn't seem to actually affect the operation of Enpass. New passwords still get synced across my devices.
August 3, 20188 yr Hi guys, Thanks for reporting this issue. The reason behind getting the error code 113 is that the internet connection is not stable on your system. So please check your internet connection and also try re-connecting the cloud sync and let me know if it works. Hope this helps!
September 1, 20188 yr On 8/3/2018 at 2:39 AM, Anshu kumar said: Hi guys, Thanks for reporting this issue. The reason behind getting the error code 113 is that the internet connection is not stable on your system. So please check your internet connection and also try re-connecting the cloud sync and let me know if it works. Hope this helps! The error happens when I wake my computer from sleep or hibernate, and Enpass has already tried syncing before my computer is fully connected to my VPN. Please add a way to delay the sync or perform a resync attempt after failed syncs.
September 3, 20188 yr Hi @Pete, Thanks for the feedback. I'm happy to forward it to the dev team to look into it. Cheers!
