August 7, 20188 yr Hi there, I am really happy to have come across your password manager software, I have already moved everything over, purchased mobile versions and shut down the paid software i was using. My feature request is based on the use case of having multiple systems at work and at home using single sign-on or AD/LDAP for authentication which equals a lot of accounts with the same username and password. Is there a way to make a primary account (for example, "Active Directory Creds" and assign multiple sites underneath that entry to use the same logon information?) Right now I have App1 - username/password App2 - username/password App3 - username/password App4 - username/password Would like to have something similar to Account Description - Username\password associated to App1 associated to App2 associated to App3 associated to App4 Does this make sense? I really want to clean up everything and not have 20 entries for the same credentials through AD. Thanks, Ben Edited August 7, 20188 yr by Ben7002 accidentally clicked the post button
August 9, 20188 yr Hi @Ben7002, Thanks for writing in. The suggested feature is already on our roadmap for the future version. Cheers!
August 9, 20188 yr Author Excellent! I knew I made the right choice of switching over to Enpass! Just makes me want a new version more now Thanks, Ben
