September 17, 20188 yr Hi, Just installed Enpass Beta 6 and have created multiple vaults however, when Enpass starts up it defaults to 'All Vaults'. Is there a way to select a default vault on opening the program rather than all vaults?
September 17, 20188 yr Hi @Nev, Thanks for writing in. I've noted down your suggestion and forwarded to the concerned team for further consideration. Cheers!
