September 17, 20188 yr Hi guys, i Use Enpass with Chrome Extension on Mac OS 10.13. I get a "Enpass Connection Error". After a while it could work again, but i cannot identify why. Reinstallation of the extension does not work. I use Version 69.0.3497.92 MAC OS 10.13.6 an the latest extension. Other browser work. I use SquidMan with an proxy server. 127.0.0.1 is set to be a direct connections in the SquidMan Settings. lsof -i:10391 shows connections from Enpass on Could you please help ...? Edited September 17, 20188 yr by baak
September 18, 20188 yr Hi @baak Sorry for the trouble caused. As per attached logs, I can see that the Chrome extension is not able to communicate with the App. To investigate it further, please share the version of Chrome browser you are using. Also, are you facing the same problem with Safari browser too? Thanks for your co-operation.
September 18, 20188 yr Author Hi Anshu, thanks for your reply. Right now the extension is working in safari and firefox. I use Chrome Version 69.0.3497.92. Cheers David
