September 20, 201610 yr I'm currently unable to use enpass in OSX and Ubuntu, although the apps launch fine any attempted use, either via enpass itself or a browser extension causes enpass to crash. Often once the crash has occurred enpass then crashes at startup unless I reboot. I use dropbox sync to sync between platforms and dropbox is showing sync_default.walletx hasn't been modified for 8 days, which seems wrong, so I think its possibly something awry with dropbox sync that is causing this issue. Any suggestion on how to work around this? Should I delete sync_default.walletx in dropbox and let enpass recreate it? I was going to attach the most recent crash log from OSX, but this forum seems only to accept image files? I also have enpass installed on my iPad but haven't dared open that to check...
September 20, 201610 yr Author Have just removed sync_default.walletx and allowed enpass on osx to recreate it. Seems to be working now. Also worked on one of the linux machines I sync too, will still need to check the other ubuntu install I was having issues with.
September 20, 201610 yr Author Ok, have now tested the Enpass in ubuntu 16 that was crashing before. All working again. Makes me wonder if having enpass open on both my desktop and laptop whilst using dropbox sync is a good idea though...
