September 26, 201610 yr well it would be great if you wouldnt always need to select the folder and just keep everything nicely contained in the enpass folder, could it be possible to make an option for that?
September 30, 20179 yr +10 This keeps me from being able to utilize Enpass w/ a USB key that I can hand off to a someone completely non-technical to make use of. I'm really not following why you couldn't add an option to enable storing the default path in the enpass.conf file if found in the current working directory of the executable.
