October 29, 20188 yr Hello Team, I am getting a connection error on chrome Enpass extension. I tried re-installing browser extension, chrome and Enpass to fix the issue but end up with no success. It's working fine on Safari though. Details: OS: macOS Mojave : 10.14 Extension: 5.5.2 Chrome: 70.0.3538.77 (Official Build) (64-bit) Enpass: 5.6.11 (155) I wrote one email to Enpass support but didn't get any response. I have paid Enpass for both iPhone and Android but I have to admit that the Enpass support is worst. Edited October 29, 20188 yr by ashishsingh4u
October 31, 20188 yr I am on High Sierra 10.13.6 (because it is a work laptop and that is what they require) and just had a MacOS software update. Now I am seeing the same thing. I can't open the Enpass browser extension. It briefly shows the connection error page, then switches to the Chrome new tab page. Same versions of Chrome, Enpass and the Enpass Chrome Extension as the previous post.
October 31, 20188 yr I'm on Mojave 10.14, using Safari 12 and EnPass 5.6.11 (155). I can't use the Safari extension (Chrome works fine), getting the same error. I've been reading the forum and it seems it's been happening for a while and no workaround yet. Well, one guy said you have to reinstall Mojave to get it fixed (not doing it) and another said to remove the HSTS.plist file, that I can't do even being root. Any other suggestion? Thanks
November 27, 20187 yr @monamour, I am getting the same, like you, on macOS Mojave 10.14.1 ; Safari 12.0.1 ; Enpass Safari extension 5.5.2 ; Enpass for Mac 5.6.11
