November 4, 20188 yr Hi, I'm using the most recent Enpass Beta on archlinux. I attached some keyfiles to my credentials, but everytime I try to export them nothing happens. Everythings works just fine on Windows, but on Linux the files don't show up/don't get deployed Edited November 4, 20188 yr by xNevo
November 6, 20187 yr I see similar things on Windows when i am trying to save attached images. If the image is named Enpass.jpg it will be saved as Enpass without the .jpg extenstion. If i manually rename the file by just adding .jpg the file is usable. On the attached image below one can see that Save as type is blank and thus will save the file without the correct extension. This is not an issue in Enpass 5.6.9.
