Spotlight Search not working
Hi all,
since the last update of Enpass 5 for iOS, the Spotlight Search won't work anymore.
I re-activated it in iOS' settings and re-installed Enpass on my iPhone.
When using spotlight to find an entry, the entry will show up in the search results.
After tapping and FaceID-ing on it, Enpass opens up with last view I was on only instead of opening the Spotlight's search result.
Is there any workaround?
And: when to expect the Enpass 6 finals?
Can't wait for it any longer :)
- remo
Hi. Why isn‘t there any feedback?
Edited by Guest
Hey @remo10
We have found the issue and notified the dev team to look into it.
Hopefully before the end of this month.
Thanks!
