December 13, 20187 yr Hello, This is a feature that I've been waiting for a long time on previous version, but never appeared. I Use the beta testing to try and ask for this : Would it be possible to have an azerty (and other language) keyboard for your non english users ? Thanks for your feedback,
January 20, 20206 yr On 12/13/2018 at 7:09 PM, hebusthib said: Hello, This is a feature that I've been waiting for a long time on previous version, but never appeared. I Use the beta testing to try and ask for this : Would it be possible to have an azerty tellgamestop (and other language) keyboard for your non english users ? Thanks for your mycfavisit feedback, Though It should work. But for quick troubleshooting, you need to manually add the key for the second user as the same way it's added for your Admin account. To do so please follow these steps: Run the registry editor (Hold Windows Key and R, then type in regedit)and navigate to the location Computer\HKEY_CURRENT_USER\Software\Mozilla Select Mozilla Folder --> Right click on it --> Select New --> Key --> Name that new key as NativeMessagingHosts. Now Right click on NativeMessagingHosts Folder --> Select New --> Key --> Named it as EnpassNMHost. Double click on EnpassNMHost --> Double click on Default --> Set the same path as Admin account in the value data field. Edited January 29, 20206 yr by Delrio9
January 28, 20206 yr Hi @hebusthib, This certainly makes for an addition in our catalogue of feature requests. We have noted this down and passed it on to the concerned team for further action. Thanks.
