December 28, 20187 yr If you had trouble updating the Enpass version from 5.6 to 6.0, follow these steps. Download version 5.6, if you do not have the installer, in this link (Softpedia). Synchronize with your previous backup in Dropbox, Google Drive or another Cloud. Click File, and then click Backup. Save the file in a safe place (remember the place). Close the old Enpass 5.6. Open the new Enpass 6. Click on Import Backup Locate the backup made in Enpass 5.6 Type Master Password and enjoy it!
December 28, 20187 yr Thanks Deyvison - you helped me with this problem! I synch with Google Drive. With 5.6 my Enpass folder was right there. Now with 6.0, after setting up synch and synching I cannot find any backup folder on Google drive. Do you by chance know where I can find it?
December 28, 20187 yr Author I do not know where to get the folder in Google Drive. However, if you have access to Enpass 5.6 you can do the steps and be able to import into Enpass 6 without problems.
December 28, 20187 yr 33 minutes ago, Rainer said: Thanks Deyvison - you helped me with this problem! I synch with Google Drive. With 5.6 my Enpass folder was right there. Now with 6.0, after setting up synch and synching I cannot find any backup folder on Google drive. Do you by chance know where I can find it? Enpass 6 uses application data folder of google drive sync for more security. It's only accessible to the application, not the user. https://developers.google.com/drive/api/v3/appdata
December 28, 20187 yr Hi Deyvison I have the same problem and am following your advice above, but on version 6 I cannot find anywhere to import a back up. the nearest I can get is File>Import, but the Enpass file it allows is a JSON file. Can you point me in the right direction please
December 28, 20187 yr Author 20 minutes ago, SteveNew User said: Hi Deyvison I have the same problem and am following your advice above, but on version 6 I cannot find anywhere to import a back up. the nearest I can get is File>Import, but the Enpass file it allows is a JSON file. Can you point me in the right direction please After creating a new safe I also could not. Try uninstalling and reinstalling the application, if a Safebox already appears, close and delete the Backup and Vaults folders from the path: Quote C:\Users\YourUser\AppData\Local\Packages\SinewSoftwareSystems.EnpassPasswordManager...\LocalState Open the Enpass again and try to import a Backup (it appears below Google Accounts, Dropbox, OneDrive). Good luck. Edited December 28, 20187 yr by Deyvison Rocha I need quote
December 28, 20187 yr Hi Deyvison Well done, thanks for that. Works fine now. They ought to make that "PC Backup restore" a bit more prominent and ensure existing users see it.
December 28, 20187 yr Author 46 minutes ago, SteveNew User said: Hi Deyvison Well done, thanks for that. Works fine now. They ought to make that "PC Backup restore" a bit more prominent and ensure existing users see it. I agree with you. Visibility should be greater for this option.
December 28, 20187 yr Hello Deyvison, YOU made my day, man! After a long way of trouble I found your advice. And after reinstall and (fortunately I had one) using a backup file, everything went fine! Thank you so much! thanks a ton from Bonn Thorsten
