please fix v6
Hello
I was so far so happy with enpass 5 (bought few month ago).
It was doing everything i needed.
simple, efficient just works
I did upgrade to version 6:
NIGHTMARE:
can’t believe how much you did ruin it!
-sync doesnt work anymore on  dropbox on ios
-Very Ugly new design
Lots of people complaigning here.
So must i lost faith???
You need urgently to correct that….Just go back to 5: It was a perfect software…
Tell me if you plan to do something, or when you wil correct the v6
Good luck
me
5 hours ago, me452 said:
Hello
NIGHTMARE:
Good luck
me
Sorry for the trouble caused to you. I'd like to inform that your Enpass 6 data location is different on the cloud than that used by Enpass 5 app. Please go through the following FAQ about how to restore Enpass 5 cloud data. Hope this resolves your issue.
