December 30, 20187 yr Hey! I'm missing a function to delete multiple fields at once in an entry, especially empty fields which I don't need for my new entry. Could you add this or at least a function to delete all unused/empty fields in an entry at once? Cheers!
January 1, 20197 yr Hi Thanks for the feedback. There should be no problem with the empty multiple fields as you see them only on the Edit page. Why exactly you want to delete the empty fields.
January 23, 20197 yr On 1/1/2019 at 4:11 PM, Hemant Kumar said: Hi Thanks for the feedback. There should be no problem with the empty multiple fields as you see them only on the Edit page. Why exactly you want to delete the empty fields. Because if there are many empty fields the it is confusing and time consuming to look for the right field when I edit the item.
