Enpass 6 sync with Google Drive fail
login Google Drive and Authorization Finished  redirect to Enpass app , the  app  is not responding.
my mac version : 10.14
Have you got both the Apple Store version and the "un-official" version installed?
I had a similar issue whereby I had both installed by mistake and after Google Auth finished, I was redirected back to the "unofficial" app rather than the Apple Store version.
If so, I suggest making a local backup of your vault, then uninstalling one or both and re-installing the Apple store version.
